Input and output on same pin - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: Input and output on same pin (/showthread.php?tid=8732) |
Input and output on same pin - david.karlas - 11-11-2025 Hi, I wonder if there is any board that fits my needs... I'm driving lights & blinds using 24VDC relays and all over the house I have buttons(lights) or up/down buttons(blinds). All this buttons have 24VDC and are connected to main junction box that has all this relays which drive 240VAC lights/blinds. I want board that has single pin(so I need to connect just 1 wire, per light) that reads that wire 24V via optocoupler at same time board has on same pin MOSFET that can drive that relay. So idea is, that I can detect when user is pressing some button and they drive lights, but at same time I can drive lights and in both cases I want to read this signals. Does such board exist? I already have KC868-A16 but as far as understand I need additional optocoupler, since I'm not allowed to connect 24VDC on input, so I need external optocoupler to simulate dry contact on KC868-A16 and makes everything ugly with additional optocoupler and 2 wires per relay. Thanks, David RE: Input and output on same pin - admin - 11-11-2025 if you want use new version, you can chose B16M controller, it made by esp32s3 , use for KCS v3 , it's newest firmware. your KC868-A16 board also can work with DC24v power supply, the digital input also can work with 24V and 0V for different logical. RE: Input and output on same pin - david.karlas - 11-11-2025 So it's safe/OK to connect 24V to KC868-A16 digital inputs? I thought I need to make dry contact with GND pin, hence I was adding octocoppler in front of it... RE: Input and output on same pin - admin - 11-11-2025 it's ok, don't worry. RE: Input and output on same pin - david.karlas - 11-11-2025 Looking at schematics at https://www.kincony.com/download/KC868-A16-schematic.pdf Under INPUT1 section, U1 EL357 has V12 on one side(in my case 24V) and on other side INPUT_D1, so I need to put INPUT_D1 to GND, I can't listen for 24V, no? RE: Input and output on same pin - admin - 11-11-2025 just directly to use by 24v ! without change anything. |
