Mqtt a16 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: Mqtt a16 (/showthread.php?tid=8767) |
Mqtt a16 - davidov.aleksandr1985@gmail - 11-25-2025 hello. help me figure out the MQTT settings on the KC868 a16 board. the task is to configure the board outputs on a third-party mqtt broker(wqtt.ru ) to work with the voice assistant (Alice) RE: Mqtt a16 - admin - 11-25-2025 just download KCS v2 firmware by usb-c cable, then set enable mqtt protocol, set the mqtt broker's ip , port, user name, password. here is KCS v2 online guide: https://www.kincony.com/esp32-kcsv2-firmware.html RE: Mqtt a16 - davidov.aleksandr1985@gmail - 11-26-2025 hello. I've already done that. but the web interface shows that there is no confirmation to the mqtt broker RE: Mqtt a16 - admin - 11-26-2025 take a photo of your mqtt setting. RE: Mqtt a16 - davidov.aleksandr1985@gmail - 11-26-2025 Поправьте меня если я где то ошибся. correct me if I made a mistake somewhere. Поправьте меня если я где то ошибся. RE: Mqtt a16 - admin - 11-26-2025 in KCS webpage, you should add "mqtt://" before your mqtt broken domain name. RE: Mqtt a16 - davidov.aleksandr1985@gmail - 11-27-2025 connected. thank you))) RE: Mqtt a16 - davidov.aleksandr1985@gmail - 12-03-2025 hello. One more question. when changing the state of the output relay manually (via a switch), should the states of all relays be sent to topik, or just one? RE: Mqtt a16 - admin - 12-03-2025 all relay will feedback. |
