Can the usb-c port be used to power another device? - Printable Version
+-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=62)
+--- Forum: F24 (https://www.kincony.com/forum/forumdisplay.php?fid=65)
+--- Thread: Can the usb-c port be used to power another device? (/showthread.php?tid=8792)
Can the usb-c port be used to power another device? - bernieke - 12-06-2025
I was thinking of powering a small switch which draws 0.6A at 5V from the usb-c port on a F24, is this possible?
RE: Can the usb-c port be used to power another device? - admin - 12-06-2025
no, can't F24 use port only use for download firmware, no 5v power.
RE: Can the usb-c port be used to power another device? - bernieke - 12-07-2025
Is there another 5V source I can use on the F24 which can safely provide 0.6A? Maybe the breadboard section or a header pin somewhere?
RE: Can the usb-c port be used to power another device? - admin - 12-07-2025
not suggest you do this way. it will let F24 unstable.
