Problems and general Feedback - Printable Version
+--- Forum: N30 (https://www.kincony.com/forum/forumdisplay.php?fid=97)
+--- Thread: Problems and general Feedback (/showthread.php?tid=8852)
Problems and general Feedback - molelightn - 12-28-2025
Hey there,
some feedback and problems we detected on two N30 devices.
  • Flash Guide with ESP Download Tool is incomplete, the guideline let you think to use the KCS bin file only. This is not correct, you will need more files (partion etc) to be able to flash.
    ESPHome Webflasher is the solution as it also accept the KCS Firmware File.
         KinCony How to
  • EnergyConsumption in kWh seems to be not working in KCS Firmware (major bug!) Same problem as in Link
  • Voltage Calibration is not possible in KCS Firmware
  • Are negative power readings possible?
  • If yes, can there be an independent energy calculation per input for positive/negative consumption readings?
br mole
RE: Problems and general Feedback - admin - 12-28-2025
EnergyConsumption can showed in KCS monitor webpage. But have bug show in home assistant by mqtt. we are checking now, later will release new firmware.
