"SmartLife" wifi transmit - Printable Version
+-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=72)
+--- Forum: TA (https://www.kincony.com/forum/forumdisplay.php?fid=76)
+--- Thread: "SmartLife" wifi transmit (/showthread.php?tid=8868)
"SmartLife" wifi transmit - hinterland - 01-02-2026
My tiny alarm seems to be transmitting a wifi signal (AP?)  "SmartLife-C886" how do i disable that?
RE: "SmartLife" wifi transmit - admin - 01-03-2026
you can set to STA mode.
RE: "SmartLife" wifi transmit - hinterland - 01-03-2026
It had 2 AP's after the firmware install, I set it to STA and one diapered and the "SmartLife" one remains.
can you take a video of your problem , send to whatsapp number: +86-15381188302
RE: "SmartLife" wifi transmit - hinterland - 01-06-2026
(01-03-2026, 11:19 AM)admin Wrote: can you take a video of your problem , send to whatsapp number: +86-15381188302
unable to send video. I unscrewed the tyua antenna and the signal strength dropped.
RE: "SmartLife" wifi transmit - admin - 01-06-2026
ok, it's also a way.
I said that to let you know the source, its coming from the tuya side on the board.....? How do I disable tuya?
RE: "SmartLife" wifi transmit - admin - 01-07-2026
if you don't want use tuya , just ignore it.
