Separate +12V to Kincony, +24V to MOSFETs - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=72) +--- Forum: T128M (https://www.kincony.com/forum/forumdisplay.php?fid=82) +--- Thread: Separate +12V to Kincony, +24V to MOSFETs (/showthread.php?tid=8902) |
Separate +12V to Kincony, +24V to MOSFETs - Toper - 01-11-2026 Hi, I have a question about power supply for T128. I'm using 24 V relays (Finder 40.52) connected to the Digital Outputs. I am considering two power options:
Thank you in advance for your help. regards, Toper RE: Separate +12V to Kincony, +24V to MOSFETs - admin - 01-11-2026 i suggest you use one 12v or 24v power supply is better. But you can also use two different power supply, just need let two power supply GND connected together. |
