KinCony E24v3 RS485 Din Rail Relay Module released - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: News (https://www.kincony.com/forum/forumdisplay.php?fid=5) +--- Thread: KinCony E24v3 RS485 Din Rail Relay Module released (/showthread.php?tid=8965) |
KinCony E24v3 RS485 Din Rail Relay Module released - admin - 01-23-2026 KinCony E24v3 RS485 Modbus Din Rail Relay Module based on ARM CPU. It have 24 manual control switch buttons can turn ON/OFF relay even if system is broken. The manual control buttons can be extend by user. The extend cable MAX support 500 meters. 24 channel removable OMRON high-quality relay. It can integrate to home assistant by ESPHome using RS485 modbus controller. ![]() Inside relay model : OMRON G2R-1-E SPDT Size: 412mm*105mm*73mm every channel output : COM,NO,NC Coil voltage: 12V or 24V MAX current: 16A at 250VAC Operation Temperature: -40~55℃ Relay consumption: 0.53W/each Mechanical life: more than 5 million times Electrical life: (under rated control capacity) more than 100,000 times (ON-OFF frequency 20 times/minute) Maximum operating frequency: 20 times/minute (under rated control capacity) 24 channel manual control buttons ![]() There are 3 control mode: a. relay control by HIGH level (12V or 24V) or LOW level (0v). (It have two different work voltage version) b. relay control by manual control buttons on board or by extend manual control buttons. c. relay control by RS485 modbus command. 4 bit DIP switch: bit 1-2-3: set RS485 address bit 4: ON: disable RS485 communication OFF: enable RS485 communication RS485 protocol: standard MODBUS protocol. default baud rate: 38400bps ![]()
