DM8 ESP32-S3 IO pins define - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=91) +--- Forum: DM8 (under designing) (https://www.kincony.com/forum/forumdisplay.php?fid=103) +--- Thread: DM8 ESP32-S3 IO pins define (/showthread.php?tid=9005) |
DM8 ESP32-S3 IO pins define - admin - 02-03-2026 SDA:GPIO8 SCL:GPIO18 PCF8574: (input1-8): i2c address:0x24 P0:input1 P1:input2 P2:input3 P3:input4 P4:input5 P5:input6 P6:input7 P7:input8 ADS1115 (4CH ADC): i2c address:0x48 Analog input (A1: DC 0-5v) Analog input (A2: DC 0-5v) Analog input (A3: DC 4-20mA) Analog input (A4: DC 4-20mA) 24C02 EPROM i2c address: 0x50 DS3231 RTC i2c address: 0x68 1-wire (pull-up resistance on PCB): 1-wire1:GPIO47 1-wire2:GPIO48 1-wire3:GPIO17 1-wire4:GPIO40 free GPIOs: GPIO13 GPIO14 GPIO21 ----------------------- Ethernet (W5500) I/O define: clk_pin: GPIO1 mosi_pin: GPIO2 miso_pin: GPIO41 cs_pin: GPIO42 interrupt_pin: GPIO43 reset_pin: GPIO44 -------------------- RS485: RXD:GPIO38 TXD:GPIO39 Tuya module: RXD:GPIO15 TXD:GPIO16 Tuya network button: Tuya module's P28 Tuya network LED: Tuya module's P16 SD Card: SPI-MOSI:GPIO10 SPI-SCK:GPIO11 SPI-MISO:GPIO12 SPI-CS:GPIO9 SD-Detect: GPIO5 ARM CPU TXD:GPIO4 ARM CPU RXD:GPIO6 |
