G1 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=66) +--- Forum: G1 (https://www.kincony.com/forum/forumdisplay.php?fid=67) +--- Thread: G1 (/showthread.php?tid=9034) |
G1 - mcdave - 02-10-2026 Hi Admin, I am planning to add a relay module to the G1, and I was wondering if you have any diagrams that I could use as a reference for how to properly add it. This correct? GPIO12 → relay IN GND → relay GND 5V → relay VCC 12V+ → COM NO → Siren+ Siren- → GND Thank you for your help. RE: G1 - admin - 02-10-2026 G1 free GPIO can't driver relay coin directly, it's no driver. not enough current. RE: G1 - mcdave - 02-10-2026 (02-10-2026, 04:20 AM)admin Wrote: G1 free GPIO can't driver relay coin directly, it's no driver. not enough current. Please confirm if I should use the relay module for this setup and verify that 12V is required to power the device on the relay side. Control side: GPIO → IN GND → GND 5V → VCC Power side: 12V+ → COM NO → Siren+ Siren– → GND This Correct? RE: G1 - admin - 02-10-2026 can you draw on paper, so that easy to understand. |
