Kincony A-128 – Digital Output LEDs glowing when OFF + module freezes when switching - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-A series and Uair Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=6) +--- Thread: Kincony A-128 – Digital Output LEDs glowing when OFF + module freezes when switching (/showthread.php?tid=9037) |
Kincony A-128 – Digital Output LEDs glowing when OFF + module freezes when switching - krzemodam2 - 02-10-2026 Hello, I am experiencing two possibly related issues with my Kincony A-128 controller. Issue 1 – Digital Output LEDs glowing when OFF Some Digital Output LEDs are glowing dimly even when the outputs are OFF in the control panel. When I turn an output ON, the LED becomes much brighter (normal behavior). Details:
Issue 2 – Module freezes when switching all outputs ON When I use Home Assistant and press a button that turns all relays ON at once, the following happens:
Load and power details
Questions
I can also provide:
Best regards RE: Kincony A-128 – Digital Output LEDs glowing when OFF + module freezes when switching - admin - 02-10-2026 what power supply you are using? what firmware you are using? RE: Kincony A-128 – Digital Output LEDs glowing when OFF + module freezes when switching - krzemodam2 - 02-10-2026 I use 2x MeanWell 150W 24V with redundancy module and DUPS with 2x 14Ah 12V AGM battery I keep around 23.9V. I use ESP Home. Below the beginning of logs: Code: INFO ESPHome 2025.5.2RE: Kincony A-128 – Digital Output LEDs glowing when OFF + module freezes when switching - admin - 02-11-2026 if you connect with power supply without UPS, whether work well. can you test with KCS v2 firmware. |
