Rs485 addresses for KC868-A6 relays - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A6 (https://www.kincony.com/forum/forumdisplay.php?fid=22) +--- Thread: Rs485 addresses for KC868-A6 relays (/showthread.php?tid=9066) |
Rs485 addresses for KC868-A6 relays - Yuriy - 02-21-2026 Hello everyone! Please, help me, what are the Rs485 addresses (for ESPhome firmware) of the KC868-A6 relays? Code: switch:Thank you in advance. RE: Rs485 addresses for KC868-A6 relays - admin - 02-21-2026 this is RS485 modbus protocol document: https://www.kincony.com/forum/showthread.php?tid=2528 RE: Rs485 addresses for KC868-A6 relays - Yuriy - 02-22-2026 (02-21-2026, 10:27 PM)admin Wrote: this is RS485 modbus protocol document: https://www.kincony.com/forum/showthread.php?tid=2528 Thank you for your answer. But in that document relays addresses described in the different format. Example from modbus_controller documentation esphome Code: switch:If i am not mistaken, it's register addresses of relays RE: Rs485 addresses for KC868-A6 relays - Yuriy - 02-22-2026 Addition KC868-A6 don’t get response by different requests (address scan, slave scan, write single coil, etc) - Timeout error, by Modbus Poll software Am I right, that Code: uart:in ESPhome firmware enough to enable modbus for KC868-A6 and it must give back response for example for request 01 05 00 00 FF 00 8C 3A by Modbus Poll? RE: Rs485 addresses for KC868-A6 relays - admin - 02-22-2026 yes, if you download KCS v2 firmware for A6 board, then enable RS485 modbus protocol, you can control relay by modbus. if you want config by ESPHome, you need config all modbus by yourself. you can see this video tour: https://youtu.be/xmBWzVGpggo RE: Rs485 addresses for KC868-A6 relays - Yuriy - 02-23-2026 (02-22-2026, 10:58 PM)admin Wrote: yes, if you download KCS v2 firmware for A6 board, then enable RS485 modbus protocol, you can control relay by modbus. Thank you for your answer. But in your video there is no ESPhome firmwere as client. If anybody know, tell me please, how can i enable modbus in clinet ESPhome firmware. Thank you in advance. |
