A18v2 MQTT Connected in Config but Shows "Disconnected" on Device Monitor – Not Detec - Printable Version
+--- Thread: A18v2 MQTT Connected in Config but Shows "Disconnected" on Device Monitor – Not Detec (/showthread.php?tid=9087)
A18v2 MQTT Connected in Config but Shows "Disconnected" on Device Monitor – Not Detec - kaobeiker - 03-04-2026
The A18v2 is configured with MQTT, but the device's own monitor shows the MQTT status as disconnected, and Home Assistant does not recognize the device.
RE: A18v2 MQTT Connected in Config but Shows "Disconnected" on Device Monitor – Not Detec - admin - 03-04-2026
check your mqtt broker. setting is correct.
i suggest you connect to another mqtt broker for a testing.
