KinCony B32M Smart Controller released - Printable Version
+--- Thread: KinCony B32M Smart Controller released (/showthread.php?tid=9103)
KinCony B32M Smart Controller released - admin - 03-05-2026
KinCony B32M ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 32 channel MOSFET output, 4 channel 1-wire GPIOs, 3 free GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card using SPI bus. B32M include DS3231 high precision RTC clock chip. LCD display will show wifi and ethernet IP address and Tuya connection state. B32M have RS485 port. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. B32M use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant.
[Image: B32M_1.jpg]
Model No. KinCony B32M
Description: KinCony 32 Channel ESP32-S3 Smart Controller – B32M
Power supply: 12-24V DC
interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6,WiFi,RS485,Bluetooth,USB-C,LCD,Tuya Module
SD Card: SPI bus
Installation method: DIN RAIL
LCD: SSD1306 I2C display
Outputs:
32CH MOSFET Outputs, every channel use MAX 10A driver IC
Inputs:
32CH dry contact inputs (optocoupler isolation, long distance circuit for MAX 500 meters cable)
free GPIO: 3CH (without pull-up resistance on PCB, connect with ESP32 pin directly)
[Image: B32M_2.jpg]
