Device change after damage - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Getting Started with ESPHome and Home Assistant (https://www.kincony.com/forum/forumdisplay.php?fid=54) +--- Thread: Device change after damage (/showthread.php?tid=9105) |
Device change after damage - OhnsorgeSebastian - 03-05-2026 Hi all. I have a question. I am using a B24M configured as MQTT with Home Assistant. After it was damaged, I bought a new device. How can I replace the device while keeping the existing integrations (so that a new device is not created, but it replaces the damaged one)? From what I see, the device is identified using a UID in the MQTT broker, so I guess I would need to somehow replace that. RE: Device change after damage - admin - 03-05-2026 yes, you only need replace the UID, different product have different UID. |
