Monitor 1 shows power=0 while Monitor 2 shows correct values - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=87) +--- Forum: N20 (https://www.kincony.com/forum/forumdisplay.php?fid=96) +--- Thread: Monitor 1 shows power=0 while Monitor 2 shows correct values (/showthread.php?tid=9123) |
Monitor 1 shows power=0 while Monitor 2 shows correct values - tombueng - 03-15-2026 My Monitor 1 shows Power=0 for all channels even if there is current which is wrong. Monitor 2 shows values correctly. Voltage / Freq 226V, 50Hz is shown on both inputs (both connect to the same phase) Protocol -> Energy has the same values for Energy 1 and 2 for all of the values of Current Factor=0.5, Power Factor=1, Energy Factor=1 Firmware v3.22.0 What might be the Problem? Is there no OTA-Update available? Do I need to connect a via USB PC to Update the Firmware? RE: Monitor 1 shows power=0 while Monitor 2 shows correct values - admin - 03-15-2026 please take a photo of your screen. KCS v3 only use by USB-C cable to download firmware. |
