# Whisper addon cannot be started on the HP Microserver
# Voice Assistant will not work
# AVX instruction set required. Not avail on Turion II
# only Instructionsets: MMX, 3DNow!, SSE, SSE2, SSE3, SSE4A,
# AMD64, AMD-V (AMD Virtualization), and EVP (Enhanced Virus Protection).
friendly_name: AS
platformio_options:
board_build.flash_mode: dio
on_boot:
- light.turn_on:
blue: 100%
brightness: 60%
effect: fast pulse
esp32:
board: esp32-s3-devkitc-1
framework:
type: esp-idf
sdkconfig_options:
CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
CONFIG_AUDIO_BOARD_CUSTOM: "y"
psram:
mode: octal # quad for N8R2 and octal for N16R8
speed: 80MHz
encryption:
key: "TFpb+pBAvQIS1MVwaA7EoJ2DkpWE+79UvVro7yMyGdU="
ota:
- platform: esphome
password: "******************"
wifi:
ssid: "wifi"
password: "***************************"
fast_connect: True
manual_ip:
static_ip: 192.168.55.127 #WiFi
gateway: 192.168.55.1
subnet: 255.255.255.0
dns1: 192.168.55.1
ap:
ssid: "Esp32-S3-Wake-Word"
password: "*************"
captive_portal:
button:
- platform: restart
light:
- platform: esp32_rmt_led_strip
rgb_order: GRB
pin: GPIO16
num_leds: 1
chipset: ws2812
name: "on board light"
effects:
- pulse:
- pulse:
transition_length: 0.5s
update_interval: 0.5s
min_brightness: 0%
max_brightness: 100%
i2s_audio:
- id: i2s_output
i2s_lrclk_pin: GPIO6 #LRC
i2s_bclk_pin: GPIO7 #BLCK
speaker:
- platform: i2s_audio
dac_type: external
sample_rate: 48000
i2s_dout_pin:
number: GPIO8
bits_per_sample: 32bit
i2s_audio_id: i2s_output
timeout: never
buffer_duration: 100ms
channel: mono
# sample_rate: 16000
# bits_per_sample: 32bit
# Virtual speakers to combine the announcement and media streams together into one output
- platform: mixer
output_speaker: i2s_audio_speaker
# num_channels: 2
num_channels: 1
source_speakers:
- id: announcement_mixing_input
timeout: never
- id: media_mixing_input
timeout: never
# Vritual speakers to resample each pipelines' audio, if necessary, as the mixer speaker requires the same sample rate
- platform: resampler
output_speaker: announcement_mixing_input
sample_rate: 48000
bits_per_sample: 16
output_speaker: media_mixing_input
sample_rate: 48000
bits_per_sample: 16
media_player:
- platform: speaker
internal: False
volume_increment: 0.05
volume_min: 0.4
# volume_max: 0.85 # when amp gain connected to ground. Avoids cutting out.
icon: mdi:speaker-wireless
announcement_pipeline:
speaker: announcement_resampling_speaker
format: FLAC # FLAC is the least processor intensive codec
num_channels: 1 # Stereo audio is unnecessary for announcements
sample_rate: 48000
media_pipeline:
speaker: media_resampling_speaker
# num_channels: 2
num_channels: 1
sample_rate: 48000
on_announcement:
- mixer_speaker.apply_ducking:
decibel_reduction: 20
duration: 0.0s
