Connecting Nextion NX3224K028 HMI display to KC868-A16S? - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-A series and Uair Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=6) +--- Thread: Connecting Nextion NX3224K028 HMI display to KC868-A16S? (/showthread.php?tid=9179) |
Connecting Nextion NX3224K028 HMI display to KC868-A16S? - markusd1984 - 03-27-2026 Is it officially supported to connect a Nextion HMI display (NX3224K028) via UART to the KC868-A16S? If yes, I need clarification on how to wire it safely:
I want to use it as a backup to control the relays in case HA / network is offline (to manage my heating thermal actuators). Thanks in advance! RE: Connecting Nextion NX3224K028 HMI display to KC868-A16S? - admin - 03-28-2026 if you don't use 4G module, you can use GSM RXD,TXD for Nextion display. GSM: RXD:GPIO15 TXD:GPIO13 5V also can get from 4G module socket, there is "V" is 5v. T is "TXD". R is "RXD" RE: Connecting Nextion NX3224K028 HMI display to KC868-A16S? - markusd1984 - 04-11-2026 (03-28-2026, 01:38 AM)admin Wrote: if you don't use 4G module, you can use GSM RXD,TXD for Nextion display. Thanks, can I use port F instead (socket for 433mhz) ? Since I already have a 4pin cable that i'd like to use. What is the layout left to right? RE: Connecting Nextion NX3224K028 HMI display to KC868-A16S? - admin - 04-12-2026 433M receiver pin have chip connected. not directly connect with esp32 pin. |
