New TA web interface unavailable - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=72) +--- Forum: TA (https://www.kincony.com/forum/forumdisplay.php?fid=76) +--- Thread: New TA web interface unavailable (/showthread.php?tid=9208) |
New TA web interface unavailable - pbouwen - 04-03-2026 Hi everyone, Just received my first Kincony device; a Tiny Alarm system. Unfortunately, I don't succeed in accessing the web interface to set it up for use with Home Assistant. I powered it with PoE and looked up the assigned IP address in my router. When I try accessing that IP in my browser, I get the message that the page can't be reached. I can ping the IP however. Rebooting the device did not help. Holding the reset button for +10 seconds also did not change anything. What other steps can I take to troubleshoot this? Should I try to reflash it? I'm using a Mac so not my preferred option. Thanks in advance for your help! RE: New TA web interface unavailable - admin - 04-03-2026 because new board no firmware inside of esp32. you should download KCS v3 firmware by usb-c cable firstly. here is KCS v3 online guide: https://www.kincony.com/how-to-use-kcsv3-firmware-esp32-board.html RE: New TA web interface unavailable - pbouwen - 04-05-2026 (04-03-2026, 11:11 PM)admin Wrote: because new board no firmware inside of esp32. you should download KCS v3 firmware by usb-c cable firstly. Thanks for your help! That worked. As it was connecting to the network and it showed up in the Tuya app (which I won't use) I incorrectly assumed that the firmware was already present. RE: New TA web interface unavailable - admin - 04-06-2026 the default firmware is our factory testing version. |
