KC868-A16 v1.6 – relays 9–16 not working in ESPHome - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-A series and Uair Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=6) +--- Thread: KC868-A16 v1.6 – relays 9–16 not working in ESPHome (/showthread.php?tid=9214) |
KC868-A16 v1.6 – relays 9–16 not working in ESPHome - dilo@interia.eu - 04-06-2026 Hi, I use KC868-A16 (version 1.6). I flashed ESPHome and I can control relays 1–8 correctly. But relays 9–16 are not working. I2C scan shows: 0x21, 0x22, 0x24, 0x25 PCF8574 at 0x24 works fine. PCF8574 at 0x25 is detected but relays don’t respond. I tried different pin mappings but still only first 8 relays work. Can you provide correct ESPHome YAML for this hardware version? Thank you. I can provide logs or photos if needed. RE: KC868-A16 v1.6 – relays 9–16 not working in ESPHome - admin - 04-06-2026 1. take a photo of your board , i want to see how you wire cable. 2. you can download KCS v2 firmware to ESP32, check 9-16 OUTPUT whether work well. if KCS firmware also can't work , it's hardware issue. |
