F16 relay stopped functioning - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=62) +--- Forum: F16 (https://www.kincony.com/forum/forumdisplay.php?fid=63) +--- Thread: F16 relay stopped functioning (/showthread.php?tid=9294) |
F16 relay stopped functioning - autolifetech - 04-27-2026 Hello, I have had the F16 for awhile now but over the past few weeks, the relays suddenly stopped working. I can control the relay functions in HA and can hear the click sound of the relay but the lights remained on (the relays are connected to light circuit). When I touch the board it is very hot.Is this normal? How to fix this issue? RE: F16 relay stopped functioning - admin - 04-27-2026 can you take a video of your problem. RE: F16 relay stopped functioning - autolifetech - 04-28-2026 I cant upload the video directly here. So here's a link to the video https://drive.google.com/file/d/1TZ8RmdabHZ_Sf5vpz65_SKRcbStR2PgE/view?usp=sharing I can hear relay click but light still on. The F16 is also hot to touch RE: F16 relay stopped functioning - admin - 04-28-2026 you can disconnect relay output wire with load. use multi meter to relay5, when turn on/off, then COM and NO whether is CLOSE and OPEN. just test without load. |
