CRC Errors with ESP Home & N10203060_KU_V20_260324SP - Printable Version
+--- Forum: N60 (https://www.kincony.com/forum/forumdisplay.php?fid=88)
+--- Thread: CRC Errors with ESP Home & N10203060_KU_V20_260324SP (/showthread.php?tid=9347)
CRC Errors with ESP Home & N10203060_KU_V20_260324SP - edalquist - 05-21-2026
I updated the ARM firmware to N10203060_KU_V20_260324SP and then tried flashing the ESP Home config from https://www.kincony.com/forum/showthread.php?tid=9157
I'm now not getting any data and the following logs repeating over and over:
[20:07:41.184][W][modbus_controller:145]: Duplicate modbus command found: type=0x3 address=100 count=68
[20:07:41.189][W][modbus_controller:145]: Duplicate modbus command found: type=0x3 address=200 count=68
[20:07:41.189][W][modbus_controller:145]: Duplicate modbus command found: type=0x3 address=600 count=68
[20:07:41.412][W][modbus:063]: Stop waiting for response from 1 424ms after last send
[20:07:41.447][W][modbus:219]: CRC check failed 1ms after last send
[20:07:41.455][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 3ms after last send
[20:07:41.468][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send
[20:07:41.713][W][modbus:063]: Stop waiting for response from 1 264ms after last send
[20:07:41.732][W][modbus:219]: CRC check failed 1ms after last send
[20:07:41.737][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 4ms after last send
[20:07:41.751][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send
[20:07:41.994][W][modbus:063]: Stop waiting for response from 1 264ms after last send
[20:07:42.015][W][modbus:219]: CRC check failed 2ms after last send
[20:07:42.021][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 5ms after last send
[20:07:42.036][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 23ms after last send
[20:07:42.402][W][modbus:063]: Stop waiting for response from 1 389ms after last send
[20:07:42.423][W][modbus:219]: CRC check failed 1ms after last send
[20:07:42.429][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 4ms after last send
[20:07:42.443][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send
[20:07:42.684][W][modbus:063]: Stop waiting for response from 1 264ms after last send
[20:07:42.705][W][modbus:219]: CRC check failed 1ms after last send
[20:07:42.710][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 4ms after last send
[20:07:42.726][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send
[20:07:42.969][W][modbus:063]: Stop waiting for response from 1 266ms after last send
[20:07:43.007][W][modbus:219]: CRC check failed 1ms after last send
[20:07:43.012][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 3ms after last send
[20:07:43.026][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send
[20:07:43.407][W][modbus:063]: Stop waiting for response from 1 401ms after last send
[20:07:43.426][W][modbus:219]: CRC check failed 1ms after last send
[20:07:43.432][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 4ms after last send
[20:07:43.445][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send
[20:07:43.690][W][modbus:063]: Stop waiting for response from 1 265ms after last send
[20:07:43.710][W][modbus:219]: CRC check failed 1ms after last send
[20:07:43.715][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 4ms after last send
[20:07:43.730][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send
[20:07:43.975][W][modbus:063]: Stop waiting for response from 1 264ms after last send
[20:07:43.996][W][modbus:219]: CRC check failed 1ms after last send
[20:07:44.001][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 4ms after last send
[20:07:44.012][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send
[20:07:44.402][W][modbus:063]: Stop waiting for response from 1 411ms after last send
[20:07:44.422][W][modbus:219]: CRC check failed 1ms after last send
[20:07:44.428][W][modbus:417]: Clearing buffer of 5 bytes - parse failed 4ms after last send
[20:07:44.441][W][modbus:417]: Clearing buffer of 3 bytes - timeout after partial response 21ms after last send
[20:07:44.687][W][modbus:063]: Stop waiting for response from 1 264ms after last send
[20:07:44.722][W][modbus:219]: CRC check failed 1ms after last send
[20:07:44.728][W][modbus:417]: Clearing buffer of 6 bytes - parse failed 3ms after last send
[20:07:44.741][W][modbus:417]: Clearing buffer of 2 bytes - timeout after partial response 21ms after last send
[20:07:44.984][W][modbus:063]: Stop waiting for response from 1 264ms after last send
[20:07:45.004][W][modbus:219]: CRC check failed 1ms after last send
[20:07:45.013][W][modbus:417]: Clearing buffer of 6 bytes - parse failed 4ms after last send
[20:07:45.024][W][modbus:417]: Clearing buffer of 2 bytes - timeout after partial response 21ms after last send
[20:07:45.407][W][modbus:063]: Stop waiting for response from 1 403ms after last send
[20:07:45.425][W][modbus:219]: CRC check failed 1ms after last send
[20:07:45.430][W][modbus:417]: Clearing buffer of 6 bytes - parse failed 4ms after last send
[20:07:45.444][W][modbus:417]: Clearing buffer of 2 bytes - timeout after partial response 21ms after last send
[20:07:45.687][W][modbus:063]: Stop waiting for response from 1 264ms after last send
[20:07:45.718][W][modbus:219]: CRC check failed 1ms after last send
[20:07:45.718][W][modbus:417]: Clearing buffer of 6 bytes - parse failed 4ms after last send
[20:07:45.727][W][modbus:417]: Clearing buffer of 2 bytes - timeout after partial response 21ms after last send
[20:07:45.971][W][modbus:063]: Stop waiting for response from 1 264ms after last send
[20:07:45.992][W][modbus:219]: CRC check failed 1ms after last send
[20:07:45.998][W][modbus:417]: Clearing buffer of 6 bytes - parse failed 4ms after last send
[20:07:46.011][W][modbus:417]: Clearing buffer of 2 bytes - timeout after partial response 21ms after last send
There are no other changes to the system, just completed that ARM firmware update and flashed the example ESP Home config
RE: CRC Errors with ESP Home & N10203060_KU_V20_260324SP - admin - 05-21-2026
you can test with KCS v3 firmware firstly. here is download link: https://www.kincony.com/forum/showthread.php?tid=9334
RE: CRC Errors with ESP Home & N10203060_KU_V20_260324SP - edalquist - 05-21-2026
Turns out I just needed to power-cycle the N60 after the updated ESP Home flash.
yes
