F24 work with TS RS485 sensor - Printable Version
+-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=62)
+--- Forum: F24 (https://www.kincony.com/forum/forumdisplay.php?fid=65)
+--- Thread: F24 work with TS RS485 sensor (/showthread.php?tid=9370)
F24 work with TS RS485 sensor - admin - 05-29-2026
Here is sample, KinCony F24 connect with one TS RS485 sensor, you can connect with multi TS sensors.
for example:
set F24 RS485 protocol = "Modbus-RTU", baud rate= 9600bps. the RS485 address should be different with TS' RS485 address.
TS sensor default address is 1, so set in "SENSOR" webpage:
Then it will work in monitor webpage:
