how to enable i2c bus for CM5 in config.txt file - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=89) +--- Forum: Pi5M32 (https://www.kincony.com/forum/forumdisplay.php?fid=111) +--- Thread: how to enable i2c bus for CM5 in config.txt file (/showthread.php?tid=9417) |
how to enable i2c bus for CM5 in config.txt file - admin - 02-23-2026 In the root of the hassos-boot partition, add a new folder called CONFIG. In the CONFIG folder, add another new folder called modules. Inside the modules folder add a text file called rpi-i2c.conf with the following content: i2c-dev In the root of the hassos-boot partition, edit the file called config.txt at last add two lines to it: dtparam=i2c_arm=on dtoverlay=i2c1-pi5,pins_2_3 restart home assistant. how to check whether have enabled i2c bus for home assistant, see here: https://www.kincony.com/forum/showthread.php?tid=9075 |
