#include <Arduino.h> // Core Arduino functions and definitions
#include <PCF8574.h> // Library for PCF8574 I2C I/O expander
#define I2C_RELAYS_ADR 0x24 // I2C address of the PCF8574 module
PCF8574 pcf(I2C_RELAYS_ADR); // Create PCF8574 object using the defined I2C address
Wire.begin(4, 5); // Parameters: SDA pin = 4, SCL pin = 5
pcf.begin(); // Initialize the PCF8574 device
// Configure all PCF8574 pins (P0–P7) as outputs
pcf.pinMode(P0, OUTPUT);
pcf.pinMode(P1, OUTPUT);
pcf.pinMode(P2, OUTPUT);
pcf.pinMode(P3, OUTPUT);
pcf.pinMode(P4, OUTPUT);
pcf.pinMode(P5, OUTPUT);
pcf.pinMode(P6, OUTPUT);
pcf.pinMode(P7, OUTPUT);
// Safe startup state
pcf.digitalWrite(P0, HIGH);
pcf.digitalWrite(P1, HIGH);
pcf.digitalWrite(P2, HIGH);
pcf.digitalWrite(P3, HIGH);
pcf.digitalWrite(P4, HIGH);
pcf.digitalWrite(P5, HIGH);
pcf.digitalWrite(P6, HIGH);
pcf.digitalWrite(P7, HIGH);
// Continuously update each PCF8574 output pin based on OpenPLC variables
// OUT_0 to OUT_7 are boolean variables provided by OpenPLC
// If OUT_x is true → set pin LOW (turn relay ON)
// If OUT_x is false → set pin HIGH (turn relay OFF)
pcf.digitalWrite(P0, OUT_0 ? LOW : HIGH);
pcf.digitalWrite(P1, OUT_1 ? LOW : HIGH);
pcf.digitalWrite(P2, OUT_2 ? LOW : HIGH);
pcf.digitalWrite(P3, OUT_3 ? LOW : HIGH);
pcf.digitalWrite(P4, OUT_4 ? LOW : HIGH);
pcf.digitalWrite(P5, OUT_5 ? LOW : HIGH);
pcf.digitalWrite(P6, OUT_6 ? LOW : HIGH);
pcf.digitalWrite(P7, OUT_7 ? LOW : HIGH);
