Request for 230VAC LEDs / Downlight - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Development (https://www.kincony.com/forum/forumdisplay.php?fid=4) +--- Thread: Request for 230VAC LEDs / Downlight (/showthread.php?tid=9501) |
Request for 230VAC LEDs / Downlight - benoitd54 - 06-17-2026 Hello, I'm currently building my house and i'm planning to be able to adjust the lighting in all my rooms (30 zones). I came across your DIN rail modules, which I think are perfect. Great job!! However, a have a quick question: how can I dim 230VAC dimmable LED spotlights / downlight from 0% to 100% without any flickering and which the real 0% (using a triac?) ? Best regards Benoit RE: Request for 230VAC LEDs / Downlight - admin - 06-17-2026 sure, you can chose DM series product + SSR driver. here is SSR driver: https://shop.kincony.com/products/0-10v-input-0-380vac-output-analog-ssr-for-dimmer-smart-controller-ac220v-driver?_pos=1&_psq=ssr&_ss=e&_v=1.0 RE: Request for 230VAC LEDs / Downlight - benoitd54 - 06-17-2026 Thanks for your reply ! ![]() Does this SSR have phase cutoff at zero crossing? RE: Request for 230VAC LEDs / Downlight - admin - 06-17-2026 yes. RE: Request for 230VAC LEDs / Downlight - benoitd54 - 06-17-2026 Thanks Finally, do you have a recommendation for a low-profile dimmable LED ceiling spotlight on AliExpress that operates at 230v and is compatible with your SSR? RE: Request for 230VAC LEDs / Downlight - admin - 06-17-2026 you can buy big company's product, it's ok. |
