KinCony Pi5R32 – Raspberry Pi CM5 IoT Gateway released - Printable Version
+--- Thread: KinCony Pi5R32 – Raspberry Pi CM5 IoT Gateway released (/showthread.php?tid=9537)
KinCony Pi5R32 – Raspberry Pi CM5 IoT Gateway released - admin - 06-24-2026
KinCony Pi5R32 – Raspberry Pi CM5 DIN Rail 32-Channel Relay Controller for Smart Home & Industrial Automation
[Image: Pi5R32-1.jpg]Product Overview
KinCony Pi5R32 is a powerful Raspberry Pi-based IoT gateway and automation controller designed for smart home, building automation, and industrial control applications. Powered by the Raspberry Pi Compute Module 5 (CM5), it integrates 32 relay outputs, 32 optocoupler-isolated digital inputs, analog inputs, PWM outputs, RS232/RS485 communication interfaces, and multiple expansion interfaces into a rugged DIN rail aluminum enclosure.
The Raspberry Pi CM5 directly controls all relay outputs, digital inputs, analog inputs, PWM outputs, and communication interfaces. Users can easily deploy automation projects using Home Assistant, Node-RED, MQTT, Modbus, Docker, Python, and other Linux-based software platforms.
Pi5R32 is ideal for large-scale automation projects requiring high-density I/O control while maintaining the flexibility of a Raspberry Pi platform.
[Image: Pi5R32-3.jpg]
Key Features
  • Powered by Raspberry Pi Compute Module 5 (CM5)
  • 32-channel relay outputs
  • 32-channel optocoupler-isolated digital inputs
  • Supports Home Assistant and Node-RED
  • RS232 and RS485 communication ports
  • 2-channel PWM outputs
  • 2 × DC 0-5V analog inputs
  • 2 × 4-20mA analog inputs
  • 20 free GPIO expansion pins
  • Gigabit Ethernet support
  • M.2 M-Key PCIe expansion socket
  • SSD1306 I2C OLED display
  • Industrial DIN rail aluminum enclosure
  • Designed for smart home and industrial automation systems
[Image: Pi5R32-7.jpg]
