KinCony Pi5M32 – Raspberry Pi CM5 IoT Gateway released - Printable Version
+--- Thread: KinCony Pi5M32 – Raspberry Pi CM5 IoT Gateway released (/showthread.php?tid=9542)
KinCony Pi5M32 – Raspberry Pi CM5 IoT Gateway released - admin - 06-25-2026
KinCony Pi5M32 – Raspberry Pi CM5 DIN Rail 32-Channel MOSFET Controller for Smart Home & Industrial Automation
[Image: Pi5M32-1.jpg]
Product Overview
KinCony Pi5M32 is a powerful Raspberry Pi-based IoT gateway and automation controller designed for smart home, industrial automation, and IoT edge computing applications. Powered by the Raspberry Pi Compute Module 5 (CM5), it integrates 32 MOSFET outputs, 32 optocoupler-isolated digital inputs, analog inputs, PWM outputs, RS232/RS485 communication interfaces, and expansion capabilities into a rugged DIN rail aluminum enclosure.
The Raspberry Pi CM5 directly controls all MOSFET outputs, digital inputs, analog inputs, PWM outputs, and communication interfaces. Users can easily deploy automation projects using Home Assistant, Node-RED, MQTT, Modbus, Docker, Python, and other Linux-based software platforms.
Pi5M32 is ideal for high-density DC load control applications such as LED lighting systems, solenoid valves, DC motors, industrial actuators, and custom automation equipment.
[Image: Pi5M32-5.jpg]
Key Features
  • Powered by Raspberry Pi Compute Module 5 (CM5)
  • 32-channel MOSFET outputs
  • 32-channel optocoupler-isolated digital inputs
  • Supports Home Assistant and Node-RED
  • RS232 and RS485 communication ports
  • 2-channel PWM outputs
  • 2 × DC 0-5V analog inputs
  • 2 × 4-20mA analog inputs
  • 20 free GPIO expansion pins
  • Gigabit Ethernet support
  • M.2 M-Key PCIe expansion socket
  • SSD1306 I2C OLED display
  • Industrial DIN rail aluminum enclosure
  • Designed for smart home and industrial automation systems
[Image: Pi5M32-7.jpg]
