Force sensitive sensor with kc868-A - Printable Version
+--- Thread: Force sensitive sensor with kc868-A (/showthread.php?tid=9547)
Force sensitive sensor with kc868-A - Elgatoguiri - 06-26-2026
Hi!
I have a Force sensitive resistor: https://www.aliexpress.com/p/order/index.html?spm=a2g0o.home.headerAcount.2.650c76dbGk3szT
I'd like to know if it's possible to directly connect it to the board and use it as switch in esphome.
Thanks!
RE: Force sensitive sensor with kc868-A - admin - 06-26-2026
can't open url
RE: Force sensitive sensor with kc868-A - Elgatoguiri - 06-26-2026
(06-26-2026, 06:49 AM)admin Wrote: can't open url
This should work:
https://es.aliexpress.com/item/1005008543988952.html?spm=a2g0o.order_list.order_list_main.53.3c211802yhvWSC&gatewayAdapt=glo2esp
the sensor detect water?
(06-26-2026, 01:09 PM)admin Wrote: the sensor detect water?
I don't think so. I haven't tried. It's supposedly be a force sensor. Detects the change of resistance when pressure is applied on the surface. I press it with my finger then it detects the change of resistance.
it can't connect to pcb directly, you need convert to analog 0-5v signal for kincony board.
RE: Force sensitive sensor with kc868-A - Elgatoguiri - 06-27-2026
(06-26-2026, 11:55 PM)admin Wrote: it can't connect to pcb directly, you need convert to analog 0-5v signal for kincony board.
OK, thank you!
