G1 powerup issue - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=66) +--- Forum: G1 (https://www.kincony.com/forum/forumdisplay.php?fid=67) +--- Thread: G1 powerup issue (/showthread.php?tid=9552) |
G1 powerup issue - beegeenz - 06-27-2026 Hello, I recently received my G1 but it seems to have some problem on powerup. When I plug in 12VDC the red LED on the board lights, the main Green LED lights, and the work Kincony appears on the small screen. But it doesn't broadcast any wifi signal and I notice the green ethernet port link LED is on, when there is no cable connected. I have all three aerials installed ok. When I connect ethernet cable the green LED turns off and the orange LED starts flashing. It looks like it did connect to my router with the name WIZnetEFFEED but there is no response when I try to go to the IP address of WIZnetEFFEED. Is there some kind of overall board reset or can I use the onboard buttons or USB port for diagnostics. Regards beegeenz RE: G1 powerup issue - admin - 06-27-2026 new board no firmware inside of ESP32. you need download KCS v3 firmware by usb-c cable firstly. here is KCS v3 online guide: https://www.kincony.com/how-to-use-kcsv3-firmware-esp32-board.html |
