Can't make AC868-A6 V1.4Sp work with Arduino IDE - Printable Version
+--- Forum: N30 (https://www.kincony.com/forum/forumdisplay.php?fid=97)
+--- Thread: Can't make AC868-A6 V1.4Sp work with Arduino IDE (/showthread.php?tid=9563)
Can't make AC868-A6 V1.4Sp work with Arduino IDE - JL_M_88 - 07-01-2026
I just acquired an AC868-A6 V1.4 board from Aliexpress.
I downloaded the lastest KCS_KC868_A6_V2.2.20.bin firmware in it
I want to give a try to Arduino IDE.
I found some ''demo programs'' on the site, such as the one below: (by the way the comment ''Blink Led on PIN0 isn't appropriate !!!)
Selected ESP32Dev Module board type
I can compile and download the program.
After downloading the program, the ESP32 will keep reseting indefintely ...
getting this message in the serial monitor:
rst:0x8 (TG1WDT_SYS_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
modeBig GrinIO, clock div:1
load:0x3fff0030,len:4876
ho 0 tail 12 room 4
load:0x40078000,len:16560
load:0x40080400,len:3500
entry 0x400805b4
ets Jul 29 2019 12:21:46
Any idea about what can be wrong there ?
Thanks
JL
 Blink led on PIN0
 by Mischianti Renzo <http://www.mischianti.org>
 https://www.mischianti.org/2019/01/02/pcf8574-i2c-digital-i-o-expander-fast-easy-usage/
#include "Arduino.h"
#include "PCF8574.h"
// Set i2c address
PCF8574 pcf8574(0x24);
void setup()
  Wire.begin(12, 11); // SDA: GPIO12, SCL: GPIO11
//  delay(1000);
  // Set pinMode to OUTPUT
  pcf8574.pinMode(P0, OUTPUT);
  pcf8574.pinMode(P1, OUTPUT);
  pcf8574.pinMode(P2, OUTPUT);
  pcf8574.pinMode(P3, OUTPUT);
  pcf8574.pinMode(P4, OUTPUT);
  pcf8574.pinMode(P5, OUTPUT);
  pcf8574.digitalWrite(P0, HIGH);
  pcf8574.digitalWrite(P1, HIGH);
  pcf8574.digitalWrite(P2, HIGH);
  pcf8574.digitalWrite(P3, HIGH);
  pcf8574.digitalWrite(P4, HIGH);
  pcf8574.digitalWrite(P5, HIGH);
  if (pcf8574.begin()){
    Serial.println("OK");
  }else{
    Serial.println("KO");
void loop()
  delay(300);
  pcf8574.digitalWrite(P0, LOW);
  delay(300);
  pcf8574.digitalWrite(P1, LOW);
  delay(300);
  pcf8574.digitalWrite(P2, LOW);
  delay(300);
  pcf8574.digitalWrite(P3, LOW);
  delay(300);
  pcf8574.digitalWrite(P4, LOW);
  delay(300);
  delay(300);
  delay(300);
  pcf8574.digitalWrite(P5, LOW)
RE: Can't make AC868-A6 V1.4Sp work with Arduino IDE - admin - 07-01-2026
you can test with our arduino demo source code firstly:
https://www.kincony.com/forum/showthread.php?tid=1866
RE: Can't make AC868-A6 V1.4Sp work with Arduino IDE - JL_M_88 - 07-02-2026
(07-01-2026, 09:57 PM)admin Wrote: you can test with our arduino demo source code firstly:
Hello!
That helped !
I was missing the right address for the PCF8574!
Would you have the addresses for all other peripheral devices on the board please ?
Thanks !
JL
RE: Can't make AC868-A6 V1.4Sp work with Arduino IDE - admin - 07-02-2026
https://www.kincony.com/forum/showthread.php?tid=1962
