N60 Voltage reference - Printable Version
+--- Forum: N60 (https://www.kincony.com/forum/forumdisplay.php?fid=88)
+--- Thread: N60 Voltage reference (/showthread.php?tid=9729)
N60 Voltage reference - Energizer - 08-10-2026
I'm in Texas, US with a normal 200a panel.
If I wanted to monitor 40 branch circuit can you explain how and what to use for voltage reference? Is it one per each 10? or is it like iotawatt that you use just one per the whole unit.
RE: N60 Voltage reference - admin - 08-10-2026
Is it one per each 10? --->Yes.
RE: N60 Voltage reference - Energizer - 08-11-2026
(08-10-2026, 10:19 PM)admin Wrote: Is it one per each 10?  --->Yes.
How do you connect the wire to the panel? You need to use special breaker or just a regular 15amp breaker will do?
RE: N60 Voltage reference - admin - 08-11-2026
regular breaker is ok.
