4-20mA loop voltage consideration - Printable Version
+-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=60)
+--- Forum: B4M (https://www.kincony.com/forum/forumdisplay.php?fid=100)
+--- Thread: 4-20mA loop voltage consideration (/showthread.php?tid=9730)
4-20mA loop voltage consideration - Armsp0 - 08-11-2026
Although the B4 and B4M devices allow connection of a 24Vdc supply it is not clear to me that the 4-20 mA analog inputs allow use of a 24 volt loop supply. The example drawings show 12 volt supply devices connected and I am concerned that I may damage the inputs by using a 24vdc loop. Please advise what is acceptable.
RE: 4-20mA loop voltage consideration - admin - 08-11-2026
yes, 24V also is ok for loop.
