Questions on CO16 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=118) +--- Forum: CO16 (https://www.kincony.com/forum/forumdisplay.php?fid=119) +--- Thread: Questions on CO16 (/showthread.php?tid=9828) |
Questions on CO16 - philj77 - 09-13-2026 Hi, I have several questions on CO16 that I would like to use to replace my alarm system :-) 1/ Are there free GPIO that can be accessed (I need to add Wiegand input) 2/ Is there a socket to expand I2C bus ? 3/ Which GPIO are used for KNX ? 4/ With ESPHome can we send KNX messages from CO16 5/ Regarding the SIM7600E expansion, what is the wiring (I already have such a module and I would like to know if it will be compatible) 6/ Any idea on how to generate sound for a remote loundspeaker (the one that tells alarm in service / door left open / ....) ? 7/ Is there any electronic between GPIO38/39 and RS485 socket ? Regards Philippe RE: Questions on CO16 - admin - 09-13-2026 1. no free gpio 2. no. 3. 4G SIM7600/KNX RXD: GPIO47 4G SIM7600/KNX TXD: GPIO48 4. ESPHome not support KNX. 5. as same as point 3. 6. use a siren control by 12v power. 7. you can check used ESP32 GPIO at here: https://www.kincony.com/forum/showthread.php?tid=9778 RE: Questions on CO16 - philj77 - 09-13-2026 (Yesterday, 01:03 PM)admin Wrote: 3. Does it mean its either KNX or SIM7600 ? RE: Questions on CO16 - admin - 09-13-2026 SIM7600 and KNX use same GPIO. two module will not plugin at the same time. you can use either module. |
