KC868-AP – max current per channel and per Vin terminal (current hardware version) - Printable Version
+--- Forum: KC868-AP / ADR (https://www.kincony.com/forum/forumdisplay.php?fid=38)
+--- Thread: KC868-AP – max current per channel and per Vin terminal (current hardware version) (/showthread.php?tid=9892)
KC868-AP – max current per channel and per Vin terminal (current hardware version) - andrzejbiardzki - 10-20-2026
I'm planning to buy the KC868-AP (16-channel PWM dimmer) and I want to make sure I size my LED strips correctly. I've found different values on your website and forum, so could you please confirm the limits for the CURRENT hardware version?
1. Max continuous current per PWM channel: is it 3A (as on the product page) or 10A (MOSFET, as mentioned on the forum in 2025)? What is the recommended safe continuous current per channel?
2. The board has two "12V/24V" input terminals, each feeding 8 PWM channels. What is the max continuous current for each of these terminals (total for its group of 8 channels)?
3. Max total current for the whole board (all 16 channels at 100% at the same time)?
4. Does the board need extra cooling at high load, or should I derate the current?
5. Which hardware version is currently shipped, and are there any differences from older versions?
My setup: 24V DC, single-color LED strips, approx. [50W] W per channel, [400] W total.
Thank you!
RE: KC868-AP – max current per channel and per Vin terminal (current hardware version) - admin - 10-20-2026
1. actually we have only one version of KC868-AP. we use the mosfet max can work with 10A, but for safety about PCB track and terminal. So on the webpage, we wrote for 3A every channel.
2. each DC "12v/24v" terminal MAX 10A.
3. you can see 3pcs of DC ORANGE color terminal. so if connect with 12v or 24v power ,total 30A for 3pcs of terminals.
4. not need.
5. only one pcb version.
