02-27-2022, 12:53 AM
Anybody interested in using the KC868-H32B with Loxone, has to select "Virtual Outputs" and import this template. After this file is imported only the IP address as per user's ip address has to be give. There is no need to configure all the 32 relays for ON and OFF commands.
Thanks for Mr wilson from Kuwait shared this config file.
VO_KC868-H32B.zip (Size: 710 bytes / Downloads: 622)
