03-12-2022, 04:28 PM
Hello
Today I have powered off the server which runs Home Assistant and Mosquitto Broker for maintenance. I have several wall switches connected to Dimmer D8 and the Dimmer D8 work mode is set to MQTT and switcher workmode to 1 key. I have observed that without an active MQTT broker all the wall switches are unresponsive. Have to press several times to turn on/off the lights.
After the MQTT broker gets online again the wall switches are working fine again.
Could you please take a look to this problem.
Thank you.
Thank you.
