09-05-2022, 03:12 AM
(This post was last modified: 09-05-2022, 06:35 AM by KinCony Support.)
[Arduino IDE demo source code for KC868-A8]--#11-Ethernet_Web server_code
KC868-A8_Web_Server-ETH.zip (Size: 33.43 MB / Downloads: 928)
* Create Your own WebServer for KC868-A8 Smart Controller*
* https://www.kincony.com **
#include "PCF8574.h"
#define DEBUG_ETHERNET_WEBSERVER_PORT Serial
// Debug Level from 0 to 4
#define _ETHERNET_WEBSERVER_LOGLEVEL_ 3
WiFiServer server(80);
// Current time
// Previous time
int flag_read_di=0;
String header;
TwoWire I2Cone = TwoWire(0);
TwoWire I2Ctwo = TwoWire(1);
//set I2C of A8
PCF8574 pcf8574_I1(&I2Cone,0x22,4,5);
PCF8574 pcf8574_R1(&I2Cone,0x24,4,5);
String relaystate[8]={"relay1state","relay2state","relay3state","relay4state",
"relay5state","relay6state","relay7state","relay8state",
void ScanKey()
for(int i=0;i<=7;i++)
delay(20);
pcf8574_R1.begin();
pcf8574_I1.pinMode(i, INPUT);
pcf8574_I1.begin();
while (!Serial);
WT32_ETH01_onEvent();
// eth_phy_type_t type=ETH_PHY_TYPE, eth_clock_mode_t clk_mode=ETH_CLK_MODE);
//WT32_ETH01_waitForConnect();
// start the web server on port 80
server.begin();
void loop(){
currentTime = millis();
previousTime = currentTime;
header += c;
client.println();
// turns 16 relays on and off
else if (header.indexOf("GET /7/on") >= 0) {relay7state = "on";pcf8574_R1.digitalWrite(P6, LOW);}
else if (header.indexOf("GET /8/on") >= 0) {relay8state = "on";pcf8574_R1.digitalWrite(P7, LOW);}
// Display the HTML web page
client.println("<style>html { font-family: Helvetica; display: inline-block; border: 3px solid green;margin: 0px auto;text-align: center;font-size: 10px;}");
if (flag_read_di==1)
client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state + " relay5:" + relay5state + " relay6:" + relay6state + " relay7:" + relay7state + " relay8:" + relay8state);
else
// Web Page Heading
client.println("<body><h1>KC868-A8 Web Server</h1>");
if (relay1state == "off") client.println("<a href=\"/1/on\"><button class=\"button\">01-OFF</button></a>"); else client.println("<a href=\"/1/off\"><button class=\"button\">01--ON </button></a>");
if (relay2state == "off") client.println("<a href=\"/2/on\"><button class=\"button\">02-OFF</button></a>"); else client.println("<a href=\"/2/off\"><button class=\"button\">02--ON </button></a>");
if (relay3state == "off") client.println("<a href=\"/3/on\"><button class=\"button\">03-OFF</button></a>"); else client.println("<a href=\"/3/off\"><button class=\"button\">03--ON </button></a>");
if (relay4state == "off") client.println("<a href=\"/4/on\"><button class=\"button\">04-OFF</button></a>"); else client.println("<a href=\"/4/off\"><button class=\"button\">04--ON </button></a>");
if (relay5state == "off") client.println("<a href=\"/5/on\"><button class=\"button\">05-OFF</button></a>"); else client.println("<a href=\"/5/off\"><button class=\"button\">05--ON </button></a>");
if (relay6state == "off") client.println("<a href=\"/6/on\"><button class=\"button\">06-OFF</button></a>"); else client.println("<a href=\"/6/off\"><button class=\"button\">06--ON </button></a>");
if (relay7state == "off") client.println("<a href=\"/7/on\"><button class=\"button\">07-OFF</button></a>"); else client.println("<a href=\"/7/off\"><button class=\"button\">07--ON </button></a>");
if (relay8state == "off") client.println("<a href=\"/8/on\"><button class=\"button\">08-OFF</button></a>"); else client.println("<a href=\"/8/off\"><button class=\"button\">08--ON </button></a>");
client.println("<a href=\"/all/on\"><button class=\"button\">All--ON</button></a>");
client.println();
break;
currentLine = "";
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("");
flag_read_di=0;
ScanKey(); //scan key
