Specifications lack of information for KC868-HxB
Question
About:
https://www.kincony.com/16-channel-ether...-h16b.html
After consulting the website and documentation. Could anyone clarify, please the following:
For the Input Ports:
What is the voltage input range / type of input / type of current for the inputs of the module?
There is NO INFORMATION regarding these ports!
f.e. DC 0-5V dry contact
or AC 230V
or whatever.
For the Output Ports:
Are they isolated? Can be used for different phases? i.e relay1: Phase1-N, relay2: Phase2-N.. relay{n} phase{1,2,3}-N
Can be the unit operated at 10A/per port continousuly? (what is the duty service?)
For the "working voltage":
What is the tolerance for the power supply? In volts or %. What is the maximun current drained, I.e. mx operational power of this unit?
In general:
What is the derrating with altitude / ambient temperature (stated as -20 to +70 C)?
Are there diagrams regarding mounting spacing required (safe areas, clear areas) and hole spacing?
I think the "product parameters" for most of the products should be updated to reflect more "basic" information.
Thank you.
1. for 6 digital input: it's dry contact signal. just short to GND means trigger. not need voltage, is you want to input voltage, use 0v/3.3v
2. for relay output, every relay use by AC250V/10A relay, but suggest use AC220v MAX3A is safety.
3. for power supply, DC12v, all relay ON, about 900mA for work current.
4. work temperature range: -20--70C
5. Thanks for suggestion, now new controller all have product parameters information.
is there any wiring schematic for this? I plan to write our own software as we need special combination of area-wise occupancy sensor and integration with FCU gateway for AC control, as well as maintaining local mqtt variables for hotel usage purpose.
thanks!
https://www.kincony.com/forum/forumdisplay.php?fid=33
