I want to trigger the IFTTT using http post, example http://192.168.1.123/ifttt/set with payload {"cmd":"run","ids":[2]}
But was returned with {"code":-1,"status":"auth failed"}
How to post to trigger the IFTTT?
Also, can I trigger the digital input using http? PDF only how to use set_output but not input
Thank you.
Thank you.
