how to test M30 by web server firmware
1. install USB driver for Windows PC. here is driver download link:
https://www.kincony.com/download/CH341SER.zip
2. download firmware BIN file (after you download ZIP file , need unzip it):
.zip   m30-factory.zip (Size: 491.68 KB / Downloads: 496)
3. use ESP32 flash download tool:
when open tool, chose "ESP32" chip:
then begin do these 5 steps to download firmware:
after you downloaded, connect ethernet cable to your router, re power on of M30 board. now the ethernet work with DHCP mode. you can login with your router to find our the M30's IP address,  then use IP address login by web browser.
ESP32 flash download tool download link:
.zip   flash_download_tool_3.9.6_0.zip (Size: 20.09 MB / Downloads: 530)
Thank you for sharing the detailed instructions! The links provided for the USB driver and ESP32 flash download tool are really helpful. I appreciate the step-by-step guidance for downloading the firmware and setting up the M30 board. Looking forward to trying this out and seeing how it works with my router. Great job!
https://www.kincony.com/forum/showthread.php?tid=6475
