Threads: 1
Hi ,
i am trying to integrate my KC868-AIO into my loxone system .
i am new to this so i am having some problems.
i have done this so far :
pc and Kincony AIO are connected to the same acces point.
i can acces the AIO tru ESPhome .
when i configure the AIO there i can find the AIO in my wireless network
i was able to connect with the download tool so the firmware V2 could be installed but there i get stuck
the download is succesful
but then i can not do anything .
if i use the scan device tool i can not find the kincony
and the wireless signal of the kincony is gone until i re install it with the esphome "install for first use".
i am sure i am making some silly fault but unexperienced me is stuck at the moment
Threads: 1,549
1. the newest KCS firmware is v2.2.2, here is download link:
https://www.kincony.com/forum/showthread.php?tid=3791
2. when you download, your address is wrong, not "0x10000" , it should be"0x0"
Threads: 1
thanks ,
i re uploaded V2.2 into my unit on adress 0x0 .
but still i find no way to connect trough eternet or wifi .
what i tried so far :
i made my computer ip static in the same range as the AIO so 192.168.1.101
i used the scan device list but when hitting scan no results
AIO is connected with ethernet to a switch pc is connected to the same switch
also pc and AIO are connected trough usb
i also tried to reset ESP32 GPIO0 (am i right to assume thats the "download" button , the top one next to the usb C input) by holding to 10+ seconds but no wifi pops up
Threads: 1,549
1. after download need re power on of board.
2. KC868-AIO and your PC should connect to same router.
how to use KCS v2, here is online guide:
https://www.kincony.com/esp32-kcsv2-firmware.html
Threads: 1
hi , i havent worked on my system in a long time but did manage to get some work into it recently .
what i done so far :
my setup :
KC868-AIO board
Loxone miniserver V1
i made a virtual ESP home using virtualbox ( will be changing that to a raspberry pi unit or kincony miniserver in the future)
uploaded a new Yaml file to ESPhome with the loxone code writen into it and aletered all inputs and outputs for loxone
i attached the yaml file also
then i did open my loxone config file and imported the UDP inputs and outputs
but i cant get both to communicate with eathother . what am i doing wrong ?
esphome-web-8af0f0 (2).zip (Size: 2.94 KB / Downloads: 574)
Threads: 1,549
do you want KC868-AIO's digital input ports and digital output ports integrate to Loxone miniserver?
if YES, when i have free time, have a test.
Threads: 1
12-02-2024, 08:11 AM
(This post was last modified: 12-02-2024, 08:52 AM by vosn1992 .)
(12-01-2024, 11:54 PM) admin Wrote: do you want KC868-AIO's digital input ports and digital output ports integrate to Loxone miniserver?
Hi , Yes , thats right , i want to use the input and output ports in Loxone .
thanks for wanting to take a look at it .
Threads: 1,549
i have tessted KC868-AIO work with Loxone Miniserver, it's OK.
i have write the yaml with 1 channel output and 1 channel input demo for you. you can enable more channels for Loxone Miniserver.
type: arduino
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
- id: bus_a
sda: 4
scl: 16
external_components:
- source:
type: git
url: https://github.com/hzkincony/esphome-loxone
ref: v1.2.1
- id: 'pcf8574_hub_out_1' # for output channel 1-16
i2c_id: bus_a
address: 0x24
pcf8575: true
- id: 'pcf8574_hub_out_2' # for output channel 17-32
i2c_id: bus_a
address: 0x25
pcf8575: true
- id: 'pcf8574_hub_out_in_3' # for output channel 33-38 + (input 49-58)
i2c_id: bus_a
address: 0x26
pcf8575: true
- id: 'pcf8574_hub_in_1' # for input channel 1-16
i2c_id: bus_a
address: 0x21
pcf8575: true
- id: 'pcf8574_hub_in_2' # for input channel 17-32
i2c_id: bus_a
address: 0x22
pcf8575: true
- id: 'pcf8574_hub_in_3' # for input channel 33-48
i2c_id: bus_a
address: 0x23
pcf8575: true
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
on_turn_on:
- lambda: !lambda |-
id(loxone1).send_string_data("RELAY-SET-255,1,1,OK");
on_turn_off:
id(loxone1).send_string_data("RELAY-SET-255,1,0,OK");
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_2
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_in_3
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
cd74hc4067:
- id: cd74hc4067_1
pin_s0:
number: 8
mode: OUTPUT
pin_s1:
number: 9
mode: OUTPUT
pin_s2:
number: 10
mode: OUTPUT
pin_s3:
number: 11
mode: OUTPUT
one_wire:
pin: GPIO5
- platform: dallas_temp
address: 0xec0921405caae128
update_interval: 10s
- platform: adc
pin: 36
update_interval: never
attenuation: 11db
- platform: adc
pin: 39
update_interval: 5s
attenuation: 11db
- platform: adc
pin: 34
update_interval: 5s
attenuation: 11db
- platform: adc
pin: 35
update_interval: 5s
attenuation: 11db
- platform: cd74hc4067
sensor: adc36
update_interval: 5s
sensor: adc36
update_interval: 5s
sensor: adc36
update_interval: 5s
sensor: adc36
update_interval: 5s
number: 4
sensor: adc36
update_interval: 5s
number: 5
sensor: adc36
update_interval: 5s
number: 6
sensor: adc36
update_interval: 5s
number: 7
sensor: adc36
update_interval: 5s
number: 8
sensor: adc36
update_interval: 5s
number: 9
sensor: adc36
update_interval: 5s
number: 10
sensor: adc36
update_interval: 5s
number: 11
sensor: adc36
update_interval: 5s
number: 12
sensor: adc36
update_interval: 5s
number: 13
sensor: adc36
update_interval: 5s
number: 14
sensor: adc36
update_interval: 5s
number: 15
sensor: adc36
update_interval: 5s
# Individual inputs
pcf8574: pcf8574_hub_in_1
on_press:
id(loxone1).send_string_data("RELAY-GET_INPUT-255,1,1,OK");
on_release:
id(loxone1).send_string_data("RELAY-GET_INPUT-255,1,0,OK");
number: 4
number: 5
number: 6
number: 7
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_in_2
number: 4
number: 5
number: 6
number: 7
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_in_3
number: 4
number: 5
number: 6
number: 7
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
number: 4
number: 5
number: 6
number: 7
number: 14
number: 15
pca9685:
frequency: 500
output:
- platform: pca9685
pca9685_id: 'pca9685_hub'
channel: 0
- platform: pca9685
channel: 1
- platform: pca9685
channel: 2
- platform: pca9685
channel: 3
- platform: pca9685
channel: 4
- platform: pca9685
channel: 5
- platform: pca9685
channel: 6
- platform: pca9685
channel: 7
- platform: pca9685
channel: 8
- platform: pca9685
channel: 9
- platform: pca9685
channel: 10
- platform: pca9685
channel: 11
- platform: pca9685
channel: 12
- platform: pca9685
channel: 13
- platform: pca9685
channel: 14
- platform: pca9685
channel: 15
light:
- platform: monochromatic
output: PWM0
output: PWM1
output: PWM2
output: PWM3
output: PWM4
output: PWM5
output: PWM6
output: PWM7
output: PWM8
output: PWM9
output: PWM10
output: PWM11
output: PWM12
output: PWM13
output: PWM14
output: PWM15
- platform: rgbw
red: PWM1
green: PWM2
blue: PWM3
white: PWM4
web_server:
port: 80
loxone:
protocol: udp
loxone_ip: "192.168.3.108"
loxone_port: 9999
listen_port: 8888
delimiter: "\n"
send_buffer_length: 64
on_string_data:
# - logger.log:
# format: "on_string_data, data=%s"
# args: [ data.c_str() ]
if (data == "RELAY-SET-255,1,1") {
id(aio_light1).turn_on();
} else if (data == "RELAY-SET-255,1,0") {
id(aio_light1).turn_off();
here is yaml file:
AIO-Loxone-ymal.txt (Size: 21.74 KB / Downloads: 431)
turn ON output1 by home assistant web page, then Loxone will update:
trigger INPUT1 with GND:
Then will feedback to Loxone config:
Loxone project download:
https://www.kincony.com/forum/attachment.php?aid=3439
Threads: 1
12-14-2024, 03:55 PM
(This post was last modified: 12-15-2024, 01:33 AM by vosn1992 .)
Hi ,
thanks for the help ,
i got further but i am running in some new problems:
if i press a virtual button in the loxone app ,
i get this state on esphome :
this is the screen i get at the same time on loxone config :
i think that looks good , but in real life the led of output 4 on the AIO does not turn on . ( i also tested with different outputs but that is the same)
when i press the switch myself in esphome the output does turn on
edit : it seems that i was wrong . the unit freezes when it sends out to the loxone for a state change . it is normaly contanstantly checking the sensor states but when changing one of the relais states and sending it to the loxone it freezes for a little longer than 2 minutes. it also occurs that the lef of the outputs flickers ones for half of a second and then turns off
edit edit : got it solved for the moment ; i changed max output buffer for loxone to 32 instead of 64 and added 100ms delay to all on or off comands for the relais . works like a charm
Threads: 1,549
