[arduino code examples for G1]-05 GSM test
#include <HardwareSerial.h>
// Define serial port
HardwareSerial SimSerial(1); // Use hardware serial port 1 (GPIO9 and GPIO10)
  // Initialize USB serial port (default serial port 0)
  while (!Serial) {
    ; // Wait for USB serial port to connect
  // Initialize SIM7600 serial port
  SimSerial.begin(115200, SERIAL_8N1, 9, 10); // RX=GPIO9, TX=GPIO10
  //Serial.println("ESP32-S3 begin work");
  // If data is received from the computer, forward it to the SIM7600 module
  if (Serial.available()) {
    while (Serial.available()) {
      char data = Serial.read();
      SimSerial.write(data);
  // If data is received from the SIM7600 module, forward it to the computer
  if (SimSerial.available()) {
    while (SimSerial.available()) {
      char data = SimSerial.read();
      Serial.write(data);
arduino ino file download:
.zip   5-GSM-Test.zip (Size: 598 bytes / Downloads: 728)
.zip   5-GSM-Test.ino.merged.zip (Size: 184.08 KB / Downloads: 809)
