02-21-2025, 05:47 AM
here is demo config file for access control panel. control OUTPUT1 or OUTPUT3 by INPUT NUMBER "101#" and "102#" by touch panel.
ESPHome yaml file download:
KC868-AIO-ESPHome-wiegand.txt (Size: 21.93 KB / Downloads: 208)
type: arduino
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
- id: bus_a
sda: 4
scl: 16
- id: 'pcf8574_hub_out_1' # for output channel 1-16
i2c_id: bus_a
address: 0x24
pcf8575: true
- id: 'pcf8574_hub_out_2' # for output channel 17-32
i2c_id: bus_a
address: 0x25
pcf8575: true
- id: 'pcf8574_hub_out_in_3' # for output channel 33-38 + (input 49-58)
i2c_id: bus_a
address: 0x26
pcf8575: true
- id: 'pcf8574_hub_in_1' # for input channel 1-16
i2c_id: bus_a
address: 0x21
pcf8575: true
- id: 'pcf8574_hub_in_2' # for input channel 17-32
i2c_id: bus_a
address: 0x22
pcf8575: true
- id: 'pcf8574_hub_in_3' # for input channel 33-48
i2c_id: bus_a
address: 0x23
pcf8575: true
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_2
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 8
mode: OUTPUT
number: 9
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
pcf8574: pcf8574_hub_out_in_3
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
cd74hc4067:
- id: cd74hc4067_1
pin_s0:
number: 8
mode: OUTPUT
pin_s1:
number: 9
mode: OUTPUT
pin_s2:
number: 10
mode: OUTPUT
pin_s3:
number: 11
mode: OUTPUT
- platform: adc
pin: 36
update_interval: never
attenuation: 11db
- platform: adc
pin: 39
update_interval: 50s
attenuation: 11db
- platform: adc
pin: 34
attenuation: 11db
- platform: adc
pin: 35
attenuation: 11db
- platform: cd74hc4067
sensor: adc36
sensor: adc36
sensor: adc36
sensor: adc36
number: 4
sensor: adc36
number: 5
sensor: adc36
number: 6
sensor: adc36
number: 7
sensor: adc36
number: 8
sensor: adc36
number: 9
sensor: adc36
number: 10
sensor: adc36
number: 11
sensor: adc36
number: 12
sensor: adc36
number: 13
sensor: adc36
number: 14
sensor: adc36
number: 15
sensor: adc36
# Individual inputs
pcf8574: pcf8574_hub_in_1
number: 4
number: 5
number: 6
number: 7
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_in_2
number: 4
number: 5
number: 6
number: 7
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
pcf8574: pcf8574_hub_in_3
number: 4
number: 5
number: 6
number: 7
number: 8
number: 9
number: 10
number: 11
number: 12
number: 13
number: 14
number: 15
number: 4
number: 5
number: 6
number: 7
number: 14
number: 15
pca9685:
frequency: 500
output:
- platform: pca9685
pca9685_id: 'pca9685_hub'
channel: 0
- platform: pca9685
channel: 1
- platform: pca9685
channel: 2
- platform: pca9685
channel: 3
- platform: pca9685
channel: 4
- platform: pca9685
channel: 5
- platform: pca9685
channel: 6
- platform: pca9685
channel: 7
- platform: pca9685
channel: 8
- platform: pca9685
channel: 9
- platform: pca9685
channel: 10
- platform: pca9685
channel: 11
- platform: pca9685
channel: 12
- platform: pca9685
channel: 13
- platform: pca9685
channel: 14
- platform: pca9685
channel: 15
light:
- platform: monochromatic
output: PWM0
output: PWM1
output: PWM2
output: PWM3
output: PWM4
output: PWM5
output: PWM6
output: PWM7
output: PWM8
output: PWM9
output: PWM10
output: PWM11
output: PWM12
output: PWM13
output: PWM14
output: PWM15
- platform: rgbw
red: PWM1
green: PWM2
blue: PWM3
white: PWM4
wiegand:
- id: mykeypad
d0: GPIO14
d1: GPIO5
on_key:
- lambda: ESP_LOGI("KEY", "received key %d", x);
on_tag:
- lambda: ESP_LOGI("TAG", "received tag %s", x.c_str());
on_raw:
- lambda: ESP_LOGI("RAW", "received raw %d bits, value %llx", bits, value);
key_collector:
- id: pincode_reader
source_id: mykeypad
min_length: 3
max_length: 3
end_keys: "#"
end_key_required: true
back_keys: "*"
clear_keys: "C"
# allowed_keys: "0123456789"
timeout: 5s
on_progress:
- logger.log:
format: "input progress: '%s', started by '%c'"
args: [ 'x.c_str()', "(start == 0 ? '~' : start)" ]
on_result:
- logger.log:
format: "input result: '%s', started by '%c', ended by '%c'"
args: [ 'x.c_str()', "(start == 0 ? '~' : start)", "(end == 0 ? '~' : end)" ]
- if:
condition:
lambda: |-
return x=="101";
then:
switch.toggle: aio_light1
- if:
condition:
lambda: |-
return x=="102";
then:
switch.toggle: aio_light2
on_timeout:
- logger.log:
format: "input timeout: '%s', started by '%c'"
args: [ 'x.c_str()', "(start == 0 ? '~' : start)" ]ESPHome yaml file download:
