09-09-2025, 02:51 AM
* KinCony DM16 16-Channel Digital Input Reader using PCF8575
* This Arduino sketch reads the state of 16 digital input channels from a
* PCF8575 I/O expander over I2C and prints their status to the serial monitor.
* Input logic:
* - Input 0 = ON
* - Input 1 = OFF (with pull-up logic)
* Hardware:
* - PCF8575 I/O Expander (I2C Address: 0x22)
* - Custom input pin mapping as defined below
* - I2C SDA pin: GPIO8
* - I2C SCL pin: GPIO18
* Author: KinCony IoT
* Website: https://www.kincony.com
* License: MIT License
#include <Wire.h>
#include "PCF8575.h"
// Define I2C pins
#define I2C_SDA 8 // SDA pin
#define I2C_SCL 18 // SCL pin
// Set the I2C address for PCF8575
PCF8575 pcf8575_IN1(0x22); // 0x22 is the I2C address for the DM16 module
// Initialize I2C with specified SDA and SCL pins
Wire.begin(I2C_SDA, I2C_SCL);
// Start communication with PCF8575 device
pcf8575_IN1.begin();
Serial.println("KinCony DM16 16 channel input state 0:ON 1:OFF");
// Define custom pin read order to match hardware mapping
uint8_t pin_order[16] = {
8, 9, 10, 11, 12, 13, 14, 15,
0, 1, 2, 3, 4, 5, 6, 7
Serial.print("Input state: ");
// Loop through all 16 pins and read their state
bool state = pcf8575_IN1.read(pin_order[i]); // Read pin state (HIGH or LOW)
Serial.print(state); // Print state: 0 = ON, 1 = OFF
Serial.print(" ");
Serial.println(); // Print new line
delay(500); // Wait for 500ms before next read
2-digital-input.zip (Size: 995 bytes / Downloads: 527)
2-digital-input.ino.merged.zip (Size: 192.34 KB / Downloads: 539)
