10-14-2025, 12:18 AM
friendly_name: HAv2
board: esp32-s3-devkitc-1
type: esp-idf
baud_rate: 0
type: W5500
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
interrupt_pin: GPIO2
reset_pin: GPIO1
external_components:
- source:
type: git
url: https://github.com/hzkincony/esphome-kc868-ha
ref: v3.0.1
uart:
- id: myuart1
tx_pin: 16
rx_pin: 17
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: false
kc868_ha:
# The binary_sensor corresponds to the state changes generated by K1~K6 on the KC868 HA board
# bind_output is required. Corresponds to the BindOutput parameter in HA485_Ctrl software
# Other parameters refer to: https://esphome.io/components/binary_sensor/index.html
- platform: kc868_ha
target_relay_controller_addr: 1 # Default value is 1, corresponds to the Target Relay Controller Addr parameter in HA485_Ctrl software
switch_adapter_addr: 10 # Default value is 10, corresponds to the Switch Adapter Addr parameter in HA485_Ctrl software
bind_output: 1 # Corresponds to the BindOutput parameter in HA485_Ctrl software
bind_output: 2
bind_output: 3
bind_output: 4
bind_output: 5
bind_output: 6
# The switch is used to control the D1~D6 level output on the KC868 HA board
# Other parameters refer to: https://esphome.io/components/switch/index.html
bind_output: 1
bind_output: 2
bind_output: 3
bind_output: 4
bind_output: 5
bind_output: 6
web_server:
port: 80
HAv2-F24-yaml.txt (Size: 3.04 KB / Downloads: 124)
