B24M: Need help connecting a wall switch to control MOSFET output
Hi KinCony team,
I have a B24M board. I want to connect a physical wall switch to a "Digital Input" and use it to turn a device on/off on the "MOSFET Output".
Could you please tell me the GPIO numbers for the inputs and outputs to use in Home Assistant?
Thanks!
i suggest you set by IFTTT with KCS v3 firmware, because if home assistant broken, wall switch also can work, the IFTTT running locally.
if you MUST want set by home assistant, the INPUT not use by gpio, it use by PCF8575 i2c chip, here is pin define:
https://www.kincony.com/forum/showthread.php?tid=8358
