Weak wifi signal/range
Glad to join the forum, there are a lot of interesting things here.
I just received my Kincony A16v3 board equipped with the display. I planned to run it directly under ESPHome.
I flashed my YAML file, but upon reboot, it wouldn't get an IP address. I finally found the issue: it worked when I placed it right next to the Wi-Fi router.
At best, I get a signal at 2.4 meters away. It's as if the built-in antenna isn't working. Is this normal?
What kind of performance/behavior are you experiencing?
Thanks for your answers!
do you have connect a IPEX wifi antenna?
another way, you can download KCS v3 firmware for a testing.
here is KCS v3 online guide: https://www.kincony.com/how-to-use-kcsv3...board.html
