09-11-2026, 09:11 PM
I recently purchased a KinCony Pi5R8 Bundle B with the CM5004000 (CM5 4GB Lite), heatsink, and fan.
I am unable to get the CM5 to boot from microSD. I am using a SanDisk High Endurance 128GB microSD card and wrote Raspberry Pi OS (64-bit) using Raspberry Pi Imager 2.0.11.1. The write and verification both complete successfully.
With the microSD installed and 12V/3A power applied:
I also installed rpiboot on Windows and connected the Pi5R8 USB-C port to the PC. rpiboot remains at “Waiting for BCM2835/6/7/2711/2712…” and does not detect the CM5.
The five DIP switches are still in their factory positions; I have not changed them.
Is there a jumper, DIP-switch setting, or other configuration required for the Pi5R8 with a CM5 Lite to boot from microSD? If not, what would you recommend checking next?
- Red power LED remains on.
- RUN/status LEDs illuminate briefly at startup and then turn off.
- Fan starts.
- No HDMI output.
- No Ethernet link/activity lights.
- Device does not appear on the network.
