Threads: 42
Threads: 1,546
1. you have not use the user name and password for your Mosquito, but i have seen set in your H32BS' network setting.
2. H32BS already support MQTT, so you can integrate directly to home assistant without use Node-Red.
3. suggest use ethernet MQTT, now i have seen you are using wifi by MQTT.
4. i think you can do as this video tour:https://youtu.be/Yrat7hVzXRw H32BS and H32B is same way for integrate with home assistant.
5. if you also have problems, you can add our technical support whatsapp, we can use teamviewer remote control your computer to help you config.
