  • 1 Vote(s) - 5 Average
how to use "KCS" firmware for KinCony ESP32 board
Note: This protocol document use for KinCony ESP32 smart controller:
KC868-A4 KC868-A6  KC868-A8 KC868-A8S KC868-A16 KC868-E16S KC868-A32 KC868-A64 KC868-A128 smart controller
Different board will have different channel of digital output, digital input , ADC, DAC, so the protocol is same , just according to the hardware resource to set channel number.
"KCS" onliine guide: https://www.kincony.com/kcs-firmware-esp32-board.html
.pdf   KCS_user_guide_v1.0.pdf (Size: 901.95 KB / Downloads: 1,477)
Hi Admin and All Member,
Im not sure if anyone have the same issue as I have. Im using a KC868-E16S I manage to upload the firmware and open the webpage. What I notice  is every time I go to protocol-->general--> and enable the MQTT, Http server, TCP server, UDP Server and RS485 and then SAVE every time it restart or reset, I cannot anymore connect to the web page and even its wifi. Appreciate if you could check on this one. Thank You.
if not used protocol, disable it. after you download, remove your USB-C cable is better.
